[Gdal-dev] gdal_merge.py question
Stephen H. Savage Stephen.Savage at asu.edu
Tue Aug 12 11:05:42 EDT 2003
Greetings,
   I'm still having difficulties getting gdal_merge to work.  I've installed
the latest version of OpenEV.  After installing the OpenEV 1.6 software, the
environment variables are set as follows:
set OPENEV_HOME=C:\PROGRA~1\Atlantis\OPENEV~1.60
set path=%OPENEV_HOME%\bin;%OPENEV_HOME%\python\Lib;%PATH%
set PYTHONHOME=%OPENEV_HOME%\python
set PYTHONPATH=%OPENEV_HOME%\pymod;%PYTHONHOME%\Numeric;%PYTHONHOME%\Lib
I tried to run this command from a DOS prompt
c:\Program Files\Atlantis\OpenEV 1.60pymod\gdal_merge.py -n 0 -o testout.tif
c:\ImageFix\34e29n_36.tif c:\ImageFix\34e30n_36.tifpymod\gdal_merge.py -n 0 -o
testout.tif c:\ImageFix\34e29n_36.tif c:\ImageFix\34e30n_36.tif
It reports this in the DOS window:
   File "C:Program Files\Atlantis\OpenEV 1.60\pymod\gdal_merge.py", line 55,
in ?
	import gdal
   File "C:Program Files\Atlantis\OpenEV 1.60\pymod\gdal_merge.py", line 156,
in ?
	import _gdal
ImportError: Module use of pyton21.dll conflicts with this version of Python.
I tried to register gdal11.dll by hand with RegSrvr.exe, but it couldn't do it.
Any suggestions?
Thanks,
-Steve
Quoting Gillian Walter <gillian.walter at atlantis-scientific.com>:
> Hi,
> You'll need to set some environment variables (PATH,PYTHONPATH,
> PYTHONHOME,OPENEVHOME).  If you look at openev.bat in openev's bin
> directory, you should see these settings.  I think gdal11.dll is in
> OpenEV's bin directory, so adding the full path of the bin directory to
> the PATH variable (and if that fails, to the PYTHONPATH variable) should
> hopefully fix things.
> -Gillian
> Stephen H. Savage wrote:
> >Greetings,
> >I've recently installed the curreent version of OpenEV.  I'm trying to
> execute
> >the command "gdal_merge.py -n 0 -o out.tif in1.tif in2.tif" and I get
> an error
> >message that reads "The application has failed because gdal11.dll was
> not
> >found..."
> >What do I need to do to make sure gdal utilities see all the .dlls and
> the like?
> >Thanks,
> >-Steve
> >Stephen H. Savage, Ph.D.
> >Department of Anthropology
> >Box 872402
> >Arizona State University
> >Tempe, AZ  85287-2402
> >shsavage at asu.edu
> >http://archaeology.asu.edu/Jordan/index.html
> >_______________________________________________
> >Gdal-dev mailing list
> >Gdal-dev at remotesensing.org
> >http://remotesensing.org/mailman/listinfo/gdal-dev
Box 872402
shsavage at asu.edu
