[Gdal-dev] DIG35 support
Ayman Kamal kamal_jo at yahoo.com
Mon Aug 18 10:36:33 EDT 2003
Thank you very much Frank for your fast and clear
respond.
Do you mean that I can (using GDAL metadata API) read
and write the DIG35 meta data?
I checked
http://www.remotesensing.org/gdal/class_GDALDataset.html
but I couldn't find functions for metadata, can you
tell me what functions do I need.
--- Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ayman Kamal wrote:
> > Hello,
> > Does GDAL support DIG35 metadata or is there any
> > intent of supporting it in the near future?
> > Here is a link for DIG35
> > http://www.i3a.org/i_dig35.html
> Ayman,
> GDAL does not have any specific support for DIG35
> metadata, which I hadn't
> heard of before your email.  Skimming the document I
> see it is an XML based
> format that can be stored in a variety of image file
> formats.
> This could be passed through the GDAL metadata API
> in a couple of different
> ways.  One is to flatten out each DIG35 metadata
> item into a seperate metadata
> item in GDAL.  The other is to treat the whole DIG35
> XML document as a single
> metadata item.
> I am not really planning on adding this for any of
> the formats in question,
> but it shouldn't be all that different if needed.
> Best regards,
> I set the clouds in motion - turn up   | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________
Do you Yahoo!?
Yahoo! SiteBuilder - Free, easy-to-use web site design software
http://sitebuilder.yahoo.com
