[Gdal-dev] Importing SRTM30 with GDAL
Ben Discoe ben at vterrain.org
Mon Aug 25 16:42:01 EDT 2003
Andrey,
I tried it last week and the SRTM30 files appeared to read into GDAL
just fine, without any tweaking.  What did you tweak?
-Ben
> -----Original Message-----
> From: Andrey Kiselev
> Sent: Monday, August 25, 2003 3:27 PM
> To: gdal-dev at remotesensing.org
> Subject: [Gdal-dev] Importing SRTM30 with GDAL
> Hi folks,
> Recently Markus pointed to the new 30 arc seconds DEMs,
> updated with the SRTM data:
> ftp://edcftp.cr.usgs.gov/pub/data/srtm/SRTM30
>I did a few tweaks in GDAL and now these data can be read with the EHdr
>(ESRI .hdr Labelled) driver. You should use raw .dem file as an input.
>		Best regards,
>		Andrey
