[Gdal-dev] ogr2ogr
Chris Faulkner chrisf at oramap.com
Thu Aug 28 02:25:14 EDT 2003
Hello
I have just started using ogr2ogr to load some shape and NTF data to
Postgres. It works rather well with one small problem - all tables and
fields are created with upper case names. In postgres, this causes some
problems with SQL - you have to quote those names and fields. Is there a way
to ask ogr2ogr to create objects with lower case names ?
Thanks
Chris
