[Gdal-dev] Windows OpenEV HDF PB
Julien Demaria dem at acri-st.fr
Fri Aug 29 10:23:38 EDT 2003
Hello,
I try GDAL today with OpenEV_FW under Windows (OpenEV_FW version 1.6.2) and
Linux (OpenEV_FW version 1.5.4) platforms.
I have problems with this HDF4 file only with the Windows version (1.6.2) :
[] /users/dem/tmp/openev_FW/bin > gdalinfo
/obe-temp/dem/S19981822003212.L3m_MC_CHLO.hdf
Driver: HDF4Image/HDF4 Dataset
Size is 4096, 2048
Coordinate System is `'
Origin = (0.000000,0.000000)
Pixel Size = (1.000000,1.000000)
Corner Coordinates:
Upper Left  (   0.0000000,   0.0000000)
Lower Left  (       0.000,    2048.000)
Upper Right (    4096.000,       0.000)
Lower Right (    4096.000,    2048.000)
Center      (    2048.000,    1024.000)
Band 1 Block=4096x1 Type=Byte, ColorInterp=Gray
under linux all works very well, but on Windows when I try to import or
open the file python.exe fails (I have a Windows popup with "cannot read
memory at ...") and all OpenEV is closed...
Maybe it's a bug between 1.5.4 and 1.6.2 version or a GDAL HDF bug under
Windows ?
Thanks in advance for help,
Julien
