[Gdal-dev] opening dataset of unknown type
Fri Dec 5 13:24:15 EST 2003
Tyler Mitchell wrote:
> I really like how you can program ogr to open a dataset without explicitly
> laying out what type it is.  I assume it tries to open it with a list of
> drivers until it succeeds, or fails altogether.  Is that right?
Tyler,
This is correct.
> Can anyone tell me how you can identify which driver format was successful?
> I'm specifically interested in how to do this in python.  I've got the
> dataset open but don't know, programatically, what type it is.  I see
> ogrinfo returns this information, but I'm not able to figure out how it
> does it.
The short answer, there is no way.
The longer answer is that I have committed changes in the gdal/pymod directory
so that the driver found in ogr.Open() can be captured somewhat like in C or
C++.  You can update from CVS to get this capability.  The new code allows you
to do the following to get the driver name for a dataset.
import ogr
x = ogr.Open( 'openev/polygon.shp' )
print x.GetDriver().GetName()
Best regards,
