[Gdal-dev] opening dataset of unknown type
Fri Dec 5 16:58:21 EST 2003
Tyler Mitchell wrote:
>>The short answer, there is no way.
>>The longer answer is that I have committed changes in the
> gdal/pymoddirectory
>>so that the driver found in ogr.Open() can be captured somewhat like in C
> or
>>C++.
> Great Frank!  Thank you very much for implementing it.  I'm trying it on
> windows, but appears that I need a new _gdal.dll I guess.  Do I need one
> built from current CVS?   I'll try to pull one together via Cygwin.
Tyler,
Right, you need to rebuild _gdal.dll from CVS.
Good luck,
