[Gdal-dev] Bigger compilation error
Paul Kelly paul-grass at stjohnspoint.co.uk
Mon Dec 15 08:04:28 EST 2003
See attached for make output, today's CVS using libtool on IRIX 6.2. It
stops at seemingly the last stage before creating the shared library. It
worked fine before (even after libtool introduction), a few months ago. I am
just sending this to the list as I'm not sure what's wrong.
Paul
Type: application/octet-stream
Desc:
Url : http://lists.osgeo.org/pipermail/gdal-dev/attachments/20031215/a12774d3/make.log.obj
