[Gdal-dev] [RFC] RasterIO speedup patch
Wed Feb 5 17:43:48 EST 2003
Tim Beckmann wrote:
> Frank and the rest of the list,
> We've been working to incorporate GDAL into our software.  One drawback
> we've found so far is that the performance of gdal when it needs to do
> data type conversions is extremely slow.  Here is a patch that I've
> generated that seems to work to improve the performance.  It works by
> changing the GDALRasterBand::IRasterIO to attempt to convert more than a
> single pixel for every call to GDALCopyWords.  For the testing I've done,
> it seems to work well.  I'm not sure if I've covered all the possible
> combinations though.  There are still cases where it falls back to calling
> GDALCopyWords once for each pixel.
> Some preliminary timings show that the runtime to convert a 100 MB Float32
> image to Byte data took 49 seconds with the original code, but only 27
> seconds with the patch below.  This is using our unreleased LAS driver on
> an SGI Origin 2000 with 250 MHz processors.
> Any comments?
Tim,
Based on a quick inspection the code looks OK.  Could you submit this
patch into bugzilla as an enhancement request?  I will have Andrey apply
and test it.
> Oh yeah, once for the record - I really dislike the naming convention used
> for variables in the routine.  It makes it much harder to understand the
> code.  >  Also, some of the variable names could use some comments to explain
> what they do (I'd add them, but I'm not 100% sure).  Example: the
> nSrcPixelOffset parameter to GDALCopyWords.  If I understand it correctly,
> it isn't an offset, it is the value to stride through the data with.
Well, I think of it as the offset from the beginning of one pixel to the
beginning of the next.  I would agree of course that more internal
documentation would be helpful.
> I also have another set of changes that cut the time nearly in half
> again...  But one step at a time.
I look forward to receiving them.
There is clearly lots of room for improvement in GDAL, at least in
cases where up/down sampling is done and/or when data type conversion is
done.   I have tried to ensure that the 1:1 IO logic (especially on
block boundaries) is efficient.
I would also add that I think I need to write some regression tests that
exercise lots of the cases so that when we tune it we can have greater
confidence that we haven't broken anything.
Best regards,
