[Gdal-dev] gdal_translate
Ayman Kamal kamal_jo at yahoo.com
Sun Feb 16 05:21:03 EST 2003
Thanks for your help, but here is my situation:
I am using Microsoft Visual Studio, and I want to be
able to create and build a project ( application )
that does the same as what gdal_translate. Simply I
want to know what do I need to accomplish this task
whether regarding needed files or other settings. I
want my application to be a stand alone application
along with the files needed with it.
--- Andrey Kiselev <dron at ak4719.spb.edu> wrote:
> On Sun, Feb 16, 2003 at 01:32:38AM -0800, Ayman
> Kamal wrote:
> > I am trying to re build the gdal_translate
> > application, but I face problems of linking. Can u
> > tell me please what are the files of the OpenEV
> sdk or
> > anyother files that I need to be able to generate
> a
> > working EXE version of the gdal_translate, and are
> > there any addtional comments u can support me with
> > about this matter?
> You should take GDAL sources in order to rebuild
> gdal_translate and
> other supplied applications. But this operation
> requires understanding
> purpose of the files in GDAL building environment.
> 1. Take latest sources here:
> ftp://ftp.remotesensing.org/gdal/daily/
> 2. Read nmake.opt file and fill it with values
> suitable for your system.
> 3. Run `nmake /f makefile.vc' command.
> 4. If you will get a building errors, report them to
> Bugzilla :-)
> Andrey V. Kiselev
> Home phone:  +7 812 5274898  ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________________________
Do you Yahoo!?
Yahoo! Shopping - Send Flowers for Valentine's Day
http://shopping.yahoo.com
