[Gdal-dev] gdal_translate
Ed McNierney ed at topozone.com
Sun Feb 16 10:34:41 EST 2003
Ayman -
If you followed my suggestions you would find the answer to those
questions.
If you need to create a Microsoft Visual Studio project, you will need
to do that yourself as it's not part of the GDAL distribution.
If you read the makefile.vc file in the apps directory, where
gdal_translate lives, you'll find exactly the header files and libraries
it uses.  You'll also need to look at the nmake.opt options file in the
root GDAL directory; the answer to your question depends (slightly) on
whether you intend to use GDAL as a DLL or statically linked.
	- Ed
Ed McNierney
President and Chief Mapmaker
TopoZone.com / Maps a la carte, Inc.
73 Princeton Street, Suite 305
North Chelmsford, MA  01863
Phone: (978) 251-4242  Fax: (978) 251-1396
ed at topozone.com
-----Original Message-----
Sent: Sunday, February 16, 2003 10:28 AM
To: gdal-dev at remotesensing.org
Subject: RE: [Gdal-dev] gdal_translate
Sir,
what I ask for is only the following:
I want to be able to build and execute gdal_translate
as a standalone project. I am using Microsoft Visual
Studio 6.0 IDE. What header files do I have to put in
the application directory and what library files do I
need to put in my workspace, and what DLLs do I have
to put in the same path of the EXE file so that the
application can survive alone.
--- Ed McNierney <ed at topozone.com> wrote:
> Ayman -
> As Andrey said, this is easy to do once you have a
> GDAL build set up.  I
> have found Frank's Windows makefiles very nicely
> arrange and easier than
> most Open Source tools to build under Windows.
> Have you downloaded the GDAL distribution?  If not,
> do so.  Then build
> it.  When you get to the point where you can build,
> say, gdal_translate
> in the apps directory, you're ready to go.  The GDAL
> download and build
> instructions are all available on the GDAL site at
> http://www.remotesensing.org/gdal
> Once you're at that point, we can get going!
> 	- Ed
> Ed McNierney
> ed at topozone.com
> From: Ayman Kamal [mailto:kamal_jo at yahoo.com]
> Sent: Sunday, February 16, 2003 8:04 AM
> Subject: Re: [Gdal-dev] gdal_translate
> what I need is a list of the
> .h files
> .lib files
> .dll files
> that I need to include in my project to be able to
> write a simple Win32 console application that can
> convert a GeoTiff file format into BMP file forma.
> That's all
> __________________________________________________
> Do you Yahoo!?
> Yahoo! Shopping - Send Flowers for Valentine's Day
> http://shopping.yahoo.com
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
Do you Yahoo!?
