[Gdal-dev] gdal_translate
Mon Feb 17 09:27:53 EST 2003
Ayman Kamal wrote:
> OK
> I will go with ur choice and use GDLA as DLL,
> can you tell me plz what are the names of the DLLs
> that I have to reference in my application and what
> are the header files to put in my application?
> My application needs only to open a GeoTiff file and
> save it as BMP.
Ayman,
Same include paths as before.  Link against gdal_i.lib, the stub library
for gdal11.dll.  Then the only DLL you need (assuming a default build) is
the gdal11.dll.
Best regards,
