[Gdal-dev] same problem on server
Andrey Kiselev dron at ak4719.spb.edu
Mon Feb 17 14:45:59 EST 2003
On Mon, Feb 17, 2003 at 10:20:38AM +0300, Vladimir Slepnev wrote:
> There's also a problem with the gdal website!
> For example, http://www.remotesensing.org/gdal/frmt_fast.html -> "404 file
> not found"
Ok, I have restored frmt_fast.html. Someone should make web-update now :-)
> And some more questions: what is the difference between the formats with
> codes EFF and FAST? Which should I use? What is the situation with the
> support of Euromap Fast Format? I can make neither head nor tail of it from
> the docs.
FAST driver designed for Landsat TM datasets and now supports only those
ones. But it may be extended for other dataset as well if I've got
samples.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
