[Gdal-dev] gdal\html
Andrey Kiselev dron at ak4719.spb.edu
Mon Feb 17 14:50:49 EST 2003
On Mon, Feb 17, 2003 at 10:16:01AM +0300, Vladimir Slepnev wrote:
> I just did a "cvs checkout gdal" (which finished successfully) and most of
> the files in gdal\html have disappeared somewhere!
Frank removed HTML docs because they are often changed along with
sources and may be builded when needed.
$ make docs
in main directory will do the work (if GNU make and Doxygen are
available).
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
