[Gdal-dev] Problem Unable to load PROJ.4
Tue Feb 18 10:33:44 EST 2003
roni zanolli wrote:
> Hi All,
> I installed gdal-1.1.8 and I'm using it with Virtual Terrain Project. My
> O.S is linux suse 8.1 and when I tried to convert a projection
> coordinate from nad27 to nad83 I get a error message
> ERROR 6: Unable to load PROJ.4 library (libproj.so), creation of
> OGRCoordinateTransformation failed.
> I installed proj-4.4.5 and the libproj.so is locate in /usr/local/lib
> and my ldconfig is set up to look to this path.
> Debugging the code I found that the file cplgetsymbol.cpp is using Dummy
> implementation instead of Unix Implemnetation because HAVE_DLFCN_H was
> not define when running configure prior to the instalation.
> So I run configure again and figure out that it is not findind most of
> my header files like
> dlfcn.h, unistd.h, fcntl.h.
> Can somebody help me with this problem?
Roni,
This is a problem with gcc 3.2 and configure.  Try grabbing the nightly
snapshot from CVS and building from that.  The configure problems should
be worked around.
Best regards,
