[Gdal-dev] FAST driver now supports IRS datasets
Andrey Kiselev dron at ak4719.spb.edu
Wed Feb 19 02:27:26 EST 2003
On Tue, Feb 18, 2003 at 07:13:46PM +0300, Andrey Kiselev wrote:
> The FAST driver now able to work with IRS datasets. As in case of
> L7A datasets (Landsat TM) administrative header should be provided to
> driver. Bands should be named as follows:
EOSAT Fast Format driver (EFF) removed from GDAL because its
functionality now covered by the FAST driver. If anyone has problems
with datsets which was previously successfully imported with EFF driver
you are encouraged to fill a bug report.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
