[Gdal-dev] Projection import from ArcInfo grid (adf)
VTP ben at vterrain.org
Mon Feb 24 18:55:03 EST 2003
I'm using GDALOpen() to read an ArcInfo binary grid file (a directory of
.adf files).  The projection is presumably specified in the file "prj.adf",
which contains the following:
Projection    LAMBERT
Zunits        NO
Units         METERS
Spheroid      CLARKE1866
Xshift        0.0000000000
Yshift        0.0000000000
Parameters
 9 56  0.000 /* 1st standard parallel
 11  0  0.000 /* 2nd standard parallel
-84 20  0.000 /* central meridian
 10 28  0.000 /* latitude of projection's origin
500000.00000 /* false easting (meters)
271820.52200 /* false northing (meters)
The dataset opens successfully and allows me to read the grid values, but
when i call GetProjectionRef(), it gives me the following string:
	"LOCAL_CS["LAMBERT",UNIT["METERS",1]]"
This seems quite wrong; it's picking up the Lambert but missing the rest of
the projection description.
This is with GDAL 1.1.8 (not from CVS).  Am i doing something wrong or is
this an issue with GDAL?
Thanks,
Ben
