[Gdal-dev] more jasper
Andrey Kiselev dron at ak4719.spb.edu
Wed Feb 26 05:10:13 EST 2003
On Wed, Feb 26, 2003 at 12:40:37AM +0300, Vladimir Slepnev wrote:
> GDAL built OK. Of course, this is not a good solution :-) The next problem
> is that I could not read any jpeg2000 files, the program always crashes on
> the GDALOpen call.
I will take a look.
> And one more question: what is the appropriate JPEG2000 GDAL driver code,
> "JPEG" or "JPEG2000"? The documentation says "JPEG", but
> GDALRegister_JPEG2000() says "JPEG2000".
JPEG driver is based on IJG libjpeg library. It is implementation of the
`old' JFIF compression standard. JPEG2000 introduces completely new
compression scheme and file layout. GDAL has two JPEG2000 drivers:
`JPEG2000' based on free JasPer library and `JP2KAK' based on non-free
Kakadu library.
JPEG and JPEG2000 are different drivers and you don't need JPEG2000 if
you only need to handle JFIF files.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
