R: [Gdal-dev] Support for creating ENVI .hdr labeled files
Andrey Kiselev dron at ak4719.spb.edu
Wed Feb 26 10:48:39 EST 2003
On Wed, Feb 26, 2003 at 04:08:22PM +0100, Vincent Schut wrote:
> > Ok, now I'm realize. Create <filename>.<ext> and <filename>.<ext>.hdr
> > instead of <filename>.img and <filename>.hdr. But does this really
> > important? :-)
> It becomes a different thing if you have written your own idl programs (envi
> is written in idl) that automatically process some envi files and that do not
> use the native envi open functions to open these files + headers, but have
> their own opening functions that are a bit more specific.
Ok. I shall add an appropriate option for more flexibility.
> I don't, I usually write these programs in C (+gdal) once I tested the
> algorithm in idl/envi :-). But maybe others have...? Btw, I thought the .img
> suffix was Erdas native/default, not ENVI's ?
Sample datasets, supplied with ENVI, has .img suffix (and named as <file>.img,
<file>.hdr)
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
