[Gdal-dev] hdf4 metadata
Norman Vine nhv at cape.com
Thu Feb 27 04:52:33 EST 2003
Andrey Kiselev writes:
> On Wed, Feb 26, 2003 at 05:38:05PM -0500, Norman Vine wrote:
> > I am not sure if the following is a problem with GDAL
> > or my hdf4 library
> > With gdalinfo I constantly get
> > Driver: HDF4/Hierarchical Data Format Release 4
> > Size is 512, 512
> > Coordinate System is `'
> > Metadata:
> >   GPOLYGONCONTAINER=-103.892405, -81.954139, -86.270138, -107.052668
> >   GRINGPOINTLATITUDE=20.525827, 17.337449, -0.496254, 2.465055
> >   GRINGPOINTSEQUENCENO=1, 2, 3, 4
> > the data for GRPOLYGONCONTAINER is I would expect for
> > GRINGPOINTLONGITUDE
> What HDF products used by you? What size of this datasets? If them has a
> reasonable size, I want get the sample.
Hi Andrey
I am working with MODIS data
There are l2 and l3 data sets in the 'images' directory of
the MODIS Ocean Color tutorial
http://jeager.gsfc.nasa.gov/modis_workshop_unh/
I suggest that we use these as our 'standard' MODIS test files
Note I hope to eventually be able to duplicate the functionality of the
matlab and IDL code in this tutorial with GDAL and Python
Cheers
Norman
