[Gdal-dev] customizing GDAL to make only two drivers available
Thu Feb 27 09:11:53 EST 2003
Norman Vine wrote:
> Ayman Kamal writes:
>>Is there any means to minimize the numbers of drivers
>>available in GDAL so that I can use it just to convert
>>from format "A" to format "B", I guess this way it
>>will be lighter weight. Can I do this? How?
> If I remember correctly you are using MSVC
> in which case I believe that you can modify the
> $GDAL_SRC/frmts/makefile.vc EXTRAFLAGS variable
> to just include the formats you want
> ie this should yield a GDAL that only did tiff and bmp
> EXTRAFLAGS =	 -DFRMT_gtiff -DFRMT_bmp
> on Unix like systems you need to modify the
> $GDAL_SRC/GDALmake.opt file variable $GDAL_FORMATS
Ayman,
Norman is right on this, though you can only control what gets
included by subdirectory of gdal/frmts, so for instance, to get any
driver in the frmts/raw directory you normally get them all.  However, they
are "light".  There are also a few dependencies between drivers that may come
up.
I would add that you can save alot by not including the OGR drivers in a GDAL
build where you only need raster support.
On windows set comment out the "INCLUDE_OGR_FRMTS" flag setting to disable
inclusino of OGR.
On Unix configure with the "--without-ogr" switch.
Best regards,
