[Gdal-dev] Can GDal uses a libtiff.dll and libgeotiff.dll
Steve Brooks sbrooks2 at kc.rr.com
Mon Jan 13 01:43:37 EST 2003
Frank,
   I have been trying to add GDal to one of my programs that already was
using libtiff and libgeotiff as DLLs.  I'm also trying to integrate the
Kakadu
library to output a geo- reference  jp2 file using the driver you wrote
as an example.
I have the jp2 file working without the geo-reference.
Per a previous message stating that the Kakadu library wasn't setup to
support
IWriteBlock, I have been taking parts of the CreateCopy code to do the
geo-reference, i.e.
JP2KAKWriteGeoTIFFInfo( jp2_target jp2_out, GDALDataset *poSrcDS );
Now my input can be one or more images at different scales and
rotations.  I already
have this part done, so that it can extract the output image at a
different scale, format,
and rotation.
This is an example of the geotiff reference with (tiepoints), and the
following attributes
GTModelTypeGeoKey = ModelTypeProjected,
GeographicTypeGeoKey  example value = 4269,
GeogCitationGeoKey example value = "Iowa South",
ProjectedCSTypeGeoKey example value = 26976,
PCSCitationGeoKey  example value = "NAD83",
ProjLinearUnitsGeoKey example value = Linear_Foot
Now since I didn't have the GDALDataset from the input I have been
searching through
GDAL trying to figure out a good way of getting the dataset with the
geotiff reference
above.  The easiest way I could see was to create an empty tiff file
with the geotiff in
it and then use GDALOpen on that file.
Well I did this and I ran into problems with having a libtiff dll linked
into my original
project and the libtiff the GDAL has statically linked to the
GDALL11.dll.
In creating the dummy tiff file I have to use TIFFSetField from the
libtiff.dll and
when XTIFFClose is called it tries to free memory that was allocated by
the libtiff.dll
and crashes.
A solution for this problem would be to have gdal11.dll to link with an
external libtiff.dll
and an external geotiff.dll.  But, before I tried this I wanted to know
if you knew any
problems before starting this.  Also, is this a proper use of gdal in
having different
end developer configurations?
Thanks
Steve Brooks
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030113/5f9cd7c5/attachment.html
