[Gdal-dev] gdal looking for proj "pj_get_def" function?
Brent Fraser bfraser at geoanalytic.com
Tue Jan 21 15:02:18 EST 2003
Frank,
  I'm attempting to test gdal_warp (GDAL 1.1.8.0, Proj4.4.5) but it gives me an error message regarding "pj_get_def":
X:\rawdata>gdalwarp -t_srs '+proj=utm +zone=11 +datum=WGS84' band1.tif UTM11_b1.tif
ERROR 1: Can't find requested entry point: pj_get_def
Usage: gdalwarp [--version] [--formats]
    [-s_srs srs_def] [-t_srs srs_def] [-order n] [-et err_threshold]
    [-te xmin ymin xmax ymax] [-tr xres yres] [-ts width height]
    [-of format] [-co "NAME=VALUE"]* srcfile dstfile
Looking at the GDAL source (ogrct.cpp, line 220), I see where it is trying to get the symbol from proj.dll,
but nowhere in my copy of the proj source does the function exist:
#ifdef PJ_VERSION >= 446
    pfn_pj_get_def = pj_get_def;
#endif
#else
    CPLPushErrorHandler( CPLQuietErrorHandler );
    pfn_pj_init = (projPJ (*)(int, char**)) CPLGetSymbol( pszLibName,
                                                       "pj_init" );
    CPLPopErrorHandler();
    if( pfn_pj_init == NULL )
       return( FALSE );
    pfn_pj_fwd = (projUV (*)(projUV,projPJ))
        CPLGetSymbol( pszLibName, "pj_fwd" );
    pfn_pj_inv = (projUV (*)(projUV,projPJ))
        CPLGetSymbol( pszLibName, "pj_inv" );
    pfn_pj_free = (void (*)(projPJ))
        CPLGetSymbol( pszLibName, "pj_free" );
    pfn_pj_transform = (int (*)(projPJ,projPJ,long,int,double*,
                                double*,double*))
                        CPLGetSymbol( pszLibName, "pj_transform" );
    pfn_pj_get_errno_ref = (int *(*)(void))
        CPLGetSymbol( pszLibName, "pj_get_errno_ref" );
    pfn_pj_strerrno = (char *(*)(int))
        CPLGetSymbol( pszLibName, "pj_strerrno" );
    pfn_pj_get_def = (char *(*)(projPJ,int))
        CPLGetSymbol( pszLibName, "pj_get_def" );
    pfn_pj_dalloc = (void (*)(void*))
        CPLGetSymbol( pszLibName, "pj_dalloc" );
#endif
Any thoughts?
Brent Fraser
GeoAnalytic Inc.
Tel:(403) 213-2700
www.geoanalytic.com
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20030121/7bc82623/attachment.html
