[Gdal-dev] Win32 binaries compiling ....
Cherkashin Evgeny eugeneai at icc.ru
Tue Jan 21 20:09:46 EST 2003
Frank Warmerdam,
> Cherkashin Evgeny wrote:
>> Hello!
>> $subj will be easy, if just to add the "call" directive to into all
>> Makefile.vc and Makefile after "do" statement, where "submake.bat" is
>> used.
"Easy" is a small methaphor. ;-)
> Cherkashin,
> What effect does this have?  The makefile seems to work fine for me without
> this.
On my system (Win 98) the process of compilation stops after considering
only the first subdirectory in the "for" statenment subdirectories list.
This is, probably, the old DOS bug. The compilation break does not allow
all the drivers to be compiled, and, then, during linking process some
gedalregister.... routines could not be found. The call statenment
corrects this problem (at least for me). In essece for some systems
there could be no change (as for You).
Consider this as increase of reliability.
> Best regards,
Evgeny
