[Gdal-dev] ntf to postgres tables --- another problem
Wed Jan 22 13:00:53 EST 2003
nida Khan wrote:
> Hi List,
> I am trying to import NTF file into postgres table,
> There are 3 layers for this NTF file, it works fine for 2 of them but fails
> on thrid one.
> This is the error I'm getting
> bash-2.05a$  ogr2ogr -update PG:dbname=test BIRMINGHAM_DISTRICT.NTF -lco
> "OVERWRITE=YES" "LAUNDER=YES" -nln birming_collection BL2000_COLLECTIONS
> ERROR 1: INSERT command for new feature failed.
> ERROR:  value too long for type character(6)
Nida,
While I gather you have dealt with this, you can also add the creation
option "PRECISION=NO" to force all string fields to use VARCHAR.  This should
avoid problems with unexpectedly long strings.
Best regards,
