[Gdal-dev] GeoTIFF file which crashes GDAL?
Ben Discoe ben at vterrain.org
Fri Jul 18 02:03:29 EDT 2003
I have a GeoTIFF which was output from the MultiSpec remote-sensing
analysis program (http://www.ece.purdue.edu/~biehl/MultiSpec/).  It
crashes in GDAL (on Windows) when i try to load it.  Tested it with
gdalinfo, and that crashes too.
I've uploaded it here: http://vterrain.org/Temp/problem.zip
It loads fine in PhotoShop, so there must be something about the
non-picture TIF elements in it.  It would be fine if GDAL gave an error
and refused to load it, but a crash is not good..
Thanks,
Ben
