[Gdal-dev] GeoTIFF file which crashes GDAL?
Vincent Schut schut at sarvision.com
Fri Jul 18 04:08:17 EDT 2003
FYI 2:
tried to open it with gimp: besides unknown tag errors, also this one:
'resolution unit meaningless'. Loads image, upper part looks fine but after
pixel 470 (more or less) a small stroke is continuously repeated. Is this how
the image should look like?
Regards,
Vincent.
On Friday 18 July 2003 08:03, Ben Discoe wrote:
> I have a GeoTIFF which was output from the MultiSpec remote-sensing
> analysis program (http://www.ece.purdue.edu/~biehl/MultiSpec/).  It
> crashes in GDAL (on Windows) when i try to load it.  Tested it with
> gdalinfo, and that crashes too.
> I've uploaded it here: http://vterrain.org/Temp/problem.zip
> It loads fine in PhotoShop, so there must be something about the
> non-picture TIF elements in it.  It would be fine if GDAL gave an error
> and refused to load it, but a crash is not good..
> Thanks,
> Ben
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
