[Gdal-dev] nmake.opt
Simon J Perkins s.perkins at lanl.gov
Fri Jul 18 10:33:50 EDT 2003
Frank Warmerdam wrote:
>> - Avoid committing nmake.opt except when absolutely necessary. Conflicts
>> will still occur now and again though.
> Simon,
> It has been my policy to only commit nmake.opt files when strictly
> necessary, and rather than committing my "working" version, I generally
> get a clean copy from CVS, make my additions, and commit that reducing
> merge/conflict issues.  Problems will sometimes still occur.
Fair enough. Unfortunately I did just commit some changes to nmake.opt a
day or two ago. They were in the necessary category I think though since
I was adding support for an additional format.  But I probably changed
more than was necessary since the nmake.opt contains my modified install
and python paths. Sorry about that to all windows users!
>>  Maintain a pristine make-template.opt in CVS, then have people copy
>> that file to nmake.opt (which would be removed from CVS control) as part
>> of the build preparation process (along with inserting the correct
>> config values into the new file).
> My issue with this is aI don't want to add a manual step for users
> starting
> new with GDAL. I link that the "nmake /f makefile.vc" command will
> generally
> work out of the box for basic builds of GDAL on windows.   If it were
> possible to have a makefile (for NMAKE) which could copy a template
> nmake.opt.in to nmake.opt if nmake.opt didn't exist, before including
> it, then
> I would be glad to make the change but I don't know of any way to
> accomplish
> this.
This seems like the correct way to do things - analgous to the configure
"template" that gets shipped with the linux version that is then used to
generate various user-specific files. On linux, the user has to type
"configure" before doing a make, and has to specify the configuration
options they want. What would be wrong with having a .bat file or VB
script, called, say, win-config, that did a similar thing to generate
nmake.opt  on windows? win-config by itself would generate a default
nmake.opt that would work fine for most people. Then various options
would be specified to change the default install path, include various
formats, and so forth. win-config itself could be a fairly generic
program that reads nmake.opt.in (or even win-config.in) to define what
options it handles and what defaults it writes out and to where. Does
anything like this exist already? If not I'll look into maybe creating
one... I don't suppose I can assume that people building GDAL from
source on windows have python installed, can I? What do people use for
scripting on windows these days? Surely there's something more advanced
than .bat files? Otherwise the win-config script might have to be a
compiled thing that gets shipped with GDAL...
Cheers,
Sy
