[Gdal-dev] build bug
Paul Kelly paul-grass at stjohnspoint.co.uk
Wed Jun 4 15:29:08 EDT 2003
Hello
On Wed, 4 Jun 2003, April Shimitz wrote:
> configure[3736]: syntax error at line 3765 : `(' unexpected
> I looked at the line, but cannot see anything wrong with it; do you see any
> or have you had any trouble with the configure script?
Maybe one of the quotes in the middle needs to be escaped also:
> print \"-L%s/lib/python%s/config -lpython%s.dll\" % (sys.prefix, sys.version[:3], sys.version[:3])'`"
                                                 ^ Change here
(I also had this problem and this fixed it)
Paul Kelly
