[Gdal-dev] gdal_translate segfaults at tiff->envi
Vincent Schut schut at sarvision.com
Thu Jun 5 10:35:21 EDT 2003
Using latest cvs, gdal_translate segfaults if I try to convert a tiff file to
envi. The conversion seems to go well (reaches 100%) but then it crashes,
apparently before closing the resulting envi file, because it is not finished
(not all data is written to disk, half of the last line is missing).
Here is the gdb backtrace:
(gdb) run -of ENVI ag_199903_cl3_PP.tif ag_199903_cl3_PP.bin
Starting program: /usr/local/bin/gdal_translate -of ENVI ag_199903_cl3_PP.tif
Input file size is 7600, 2460
0...10...20...30...40...50...60...70...80...90...100 - done.
Program received signal SIGSEGV, Segmentation fault.
0x405494a1 in strstr () from /lib/i686/libc.so.6
(gdb) backtrace
#0  0x405494a1 in strstr () from /lib/i686/libc.so.6
#1  0x4027bb47 in typeinfo name for DOQ1Dataset () from
/usr/local/lib/libgdal.1.1.so
#2  0x400c6668 in ENVIDataset::~ENVIDataset() () from
#3  0x4014c817 in GDALClose () from /usr/local/lib/libgdal.1.1.so
#4  0x0804a3ab in main ()
#5  0x404ec082 in __libc_start_main () from /lib/i686/libc.so.6
(gdb) q
Regards,
Vincent Schut.
______________________________________
Vincent Schut
Sarvision B.V.
Wageningen, The Netherlands
www.sarvision.com
