[Gdal-dev] [ANNOUNCE]: MODIS Level 3 products now supported
Norman Vine nhv at cape.com
Tue Jun 10 08:05:56 EDT 2003
Hi Andrey,
Good show :-)
Will let you know if I encounter any problems.
Any plans regarding MODIS Level 2 products ?
Cheers
Norman
> -----Original Message-----
> From: gdal-dev-admin at remotesensing.org
> [mailto:gdal-dev-admin at remotesensing.org]On Behalf Of Andrey Kiselev
> Sent: Tuesday, June 10, 2003 5:48 AM
> To: gdal-dev at remotesensing.org
> Subject: [Gdal-dev] [ANNOUNCE]: MODIS Level 3 products now supported
> Hi, folks,
> HDF4 driver now supports MODIS Level 3 global data products. Coordinate
> system information and geotransformation matrix properly extracted, so
> these datasets may be used directly as an input for `gdalwarptest' tool.
> There are a variety different MODIS L3 products and I'm believe all of
> them are supported now. By the way, please, report any experienced
> troubles with such data. `gdalinfo' output should be enough for me to
> track the problem.
> 					Best regards,
> 					Andrey
> Andrey V. Kiselev
> Home phone:  +7 812 5274898  ICQ# 26871517
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
