[Gdal-dev] Bug fix in BMP support
Tue Jun 17 13:09:02 EDT 2003
Andrey Kiselev wrote:
> On Tue, Jun 17, 2003 at 09:24:41AM -0400, Frank Warmerdam wrote:
>>I would add that I don't see why bmpdataset.cpp should even be closing the
>>file managed by the GDALOpenInfo.  Do you have a specific reason this needs
>>to be done?  If not, please don't.
> Frank,
> I want reopen the file with large-file interface, so I'm closing opened
> handler before reopening. Why do you think it is wrong?
The general practice would be to go ahead and open it with the large file API,
but not to close the regular file handle.  The GDALOpen() API will take care
of it later.  I generally try to only fiddle with the GDALOpenInfo's file
pointer when I want to "adopt it" in the driver, in which case I set the
pointer to NULL, taking ownership of it.
However, there isn't really any harm in your closing it ... it just seems
Of course, using the wrong API function to close it is ... wrong.
Best regards,
