[Gdal-dev] "core" renamed to "gcore"
Gerald Buckmaster gbuckmaster at cox.net
Fri Jun 27 21:02:01 EDT 2003
Frank,
My attempt to configure OpenEV really wants that core directory - what do I
need to edit for configure to look for gcore directory instead...guess I
could grep for it.
Gerald
Using requested GDAL_HOME of /usr/local/src/gdal
configure: error: 'Unable to find /usr/local/src/gdal/core directory, are you
sure a
regular GDAL build tree can be found at /usr/local/src/gdal?'
On Friday 27 June 2003 12:08 pm, Frank Warmerdam wrote:
> Folks,
> This is just to warn that I am changing the name of the gdal/core directory
> to gdal/gcore to avoid all the problems with configure scripts trying to
> delete it.  Things will be in flux for a bit due to this.  Anyone with a
> CVS tree checked out will need to do "cvs update -d" in the main gdal
> directory to get the new directory checked out, and the old one will likely
> have to be removed manually.
> I expect to have a gdal-1.1.9 beta up for review later this afternoon.
> Best regards,
