[Gdal-dev] Gettting Image Resolution
Ayman Kamal kamal_jo at yahoo.com
Mon Mar 3 01:40:05 EST 2003
Actually what I am looking for is DPI ( Dots Per Inch
--- Frank Warmerdam <warmerdam at pobox.com> wrote:
> Ayman Kamal wrote:
> > How can I get the resolution of the image using
> GDAL?
> Hi,
> I assume you are wanting the size of a pixel in
> georeferenced coordinates?
> If so, use the GetGeoTransform() method on the
> GDALDataset. It fills in a
> six parameter double array.  geotransform[1] is
> normally the width of a
> pixel, and geotransform[5] is usually the height of
> a pixel negated.
> If the image is rotated things are more complicated.
> Best regards,
> I set the clouds in motion - turn up   | Frank
> Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows |
> http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________________________
Do you Yahoo!?
Yahoo! Tax Center - forms, calculators, tips, more
http://taxes.yahoo.com/
