[Gdal-dev] Tiger Polygons
Thomas Hargrove ciagon at yourmom.sh
Wed Mar 5 01:16:35 EST 2003
I got tigerpoly to run!  It segfaults at the end, but after it has produced
a useable shapefile.
Now that I have the polys, I need to filter them into county, water,
landmarks, and urban areas.  I take it this need to be done in python.
I see what you mean when you said it will be a lot of work.  Unfortunately,
I need these polys to draw useable maps with my map server.
Assuming that the tigerpoly.py spit out all the attributes, could I simply
use "ogr2ogr --where..." to get the 4 sets of poly's I need, or is there
more processing that needs to take place?
--Tom
> Tom,
> Arggg.  I believe this is related to the version of swig used to generate
> the gdal_wrap.c.  I would suggest deleting the gdal_wrap.c you have,
> doing a cvs update, and then touching the new one so that the makefile
won't
> try to regenerate it.
> It seems to be an issue about whether the swig wrappers consider None to
> mean NULL in C.  At least one specific version of swig does (the one I
usually
> use), but others do not (like what I have on my new redhat system).
> If the above doesn't solve the problem let me know.  I will be committing
a
> version of ogr.py that tries to handle the need for 'NULL' gracefully.
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
