[Gdal-dev] [RFC] RasterIO speedup patch
    Tim Beckmann
    tbeckman at usgs.gov
    Mon Mar 10 09:07:33 EST 2003
Andrey,
Thanks for the update.  I'm not surprised my change wasn't 100% correct.
The RasterIO function is extremely complicated and pretty much
undocumented.   The change did work for the one driver I tested ;).  I
will try out your change when I get a chance.
Thanks
Tim
Tim Beckmann               tbeckman at usgs.gov
Software Project Lead
SAIC
EROS Data Center, Sioux Falls, SD 57198
605-594-2521    Phone
605-594-6940    Fax
Andrey Kiselev <dron at ak4719.spb.edu>
Sent by: gdal-dev-admin at remotesensing.org
03/09/2003 04:28 AM
Please respond to gdal-dev
        To:     gdal-dev at remotesensing.org
        cc:
        Subject:        Re: [Gdal-dev] [RFC] RasterIO speedup patch
Hi, Tim,
On Wed, Feb 05, 2003 at 04:31:02PM -0600, Tim Beckmann wrote:
> We've been working to incorporate GDAL into our software.  One drawback
> we've found so far is that the performance of gdal when it needs to do
> data type conversions is extremely slow.  Here is a patch that I've
> generated that seems to work to improve the performance.  It works by
> changing the GDALRasterBand::IRasterIO to attempt to convert more than a
> single pixel for every call to GDALCopyWords.  For the testing I've
done,
> it seems to work well.  I'm not sure if I've covered all the possible
> combinations though.  There are still cases where it falls back to
calling
> GDALCopyWords once for each pixel.
Please, look at latest improvements in GDALRasterBand::IRasterIO()
implementation. Unfortunately I have rejected your patch because it was
wrong and results in segfaults. But with my latest changes IRasterIO()
works significally faster than before (4 times faster in many cases).
Slowest part of IRasterIO() is the case when we need perform resampling
and it stays untouched, but in all cases when resampling don't needed
IRasterIO() works much better now.
        Regards,
        Andrey
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
Gdal-dev mailing list
Gdal-dev at remotesensing.org
http://remotesensing.org/mailman/listinfo/gdal-dev
