[Gdal-dev] gdal_translate
Mon Mar 10 09:35:08 EST 2003
Ayman Kamal wrote:
> I used your application gdal_translate to convert a 16
> bit GeoTiff file to an 8 bit bmp file using command
> line arguments:
> and it worked fine,
> I then switched to  your source code of gdal_translate
> and put all the needed dlls and lib files and it
> compiled correctly, but the result of its conversion
> for the same file resulted in an image all black, why
> is that?
Ayman,
I don't know.
Best regards,
