[Gdal-dev] Landsat 7 data
Horst Reinecke hreinec at gwdg.de
Wed Mar 12 08:21:15 EST 2003
Am Mittwoch, 12. März 2003 14:08 schrieben Sie:
> On Wed, Mar 12, 2003 at 01:30:01PM +0100, Horst Reinecke wrote:
> > i trying to read FASTL7 data with grass5.0 (r.in.gdal) or gdalinfo. Both
> > times i get the answer "ERROR 4: <filename> not recognised as supported
> > fileformat". I using gdal-bibliothek 1.1.8. What wrong?
> Probably you supply r.in.gdal with wrong file. You should read header
> file, not the binary image itself.
Thanks, but I took the headerfiles xxx_hpn.fst xxx_hfr.fst and xxx_htm.fst.
