[Gdal-dev] SDTS-TVP
Thu Mar 13 12:25:47 EST 2003
Sylvain Rioux wrote:
> Hi,
> When I try to open an SDTS-TVP my system crash. Is there something I can
> do to activate SDTS? If not, I put a sample on my web site that you can
> download to see what is happening
> http://www.softmaptech.net/GDAL/GC4_hydro_sdts.tar.gz.
Sylvain,
I have tried "ogr2ogr out HY01CATD.DDF" and it seemed to translate to
shapefiles OK.  Does this work for you?  Since I can't trivially reproduce
the problem you will likely need to debug into the library a bit yourself.
Best regards,
