[Gdal-dev] IRasterIO Problems?
Simon Perkins s.perkins at lanl.gov
Mon Mar 17 15:52:17 EST 2003
Just a heads up that I've started getting a segmentation fault using
existing code with the latest version of GDAL. My code works fine with
the version of GDAL in CVS prior to March 9th. On that date a bunch of
changes were checked in for rasterio.cpp and the problem seems to be in
that file.
The problem occurs loading in smallish windows (50x50ish) from a medium
sized (450x400ish) four-band byte FITS image.
More news when I get it, unless someone has already solved something
like this and lets me know first!
Sy
