[Gdal-dev] Re: IRasterIO Problems?
Simon Perkins s.perkins at lanl.gov
Mon Mar 17 18:43:40 EST 2003
On Mon, 2003-03-17 at 13:52, Simon Perkins wrote:
> Just a heads up that I've started getting a segmentation fault using
> existing code with the latest version of GDAL. My code works fine with
> the version of GDAL in CVS prior to March 9th. On that date a bunch of
> changes were checked in for rasterio.cpp and the problem seems to be in
> that file.
This turned out to be a false alarm after all...
Frank committed some changes a few days ago that fixed things. My source
_was_ from today's CVS but my code was picking up a random copy of the
library that was a few days older... It's all so embarrassing.
Cheers,
Sy
