[Gdal-dev] problem with converting GeoTiff to BMP
Ayman Kamal kamal_jo at yahoo.com
Sun Mar 23 11:47:39 EST 2003
I have tested many geotiff files, all of them had a
result of (Band 1 ) using "gdalinfo", but all of them
worked properly using "AddComplexSource"
--- Norman Vine <nhv at cape.com> wrote:
> Ayman Kamal writes:
> > I have a GeoTiff file with the following data
> > generated from "gdalinfo". I converted this file
> using
> > "gdal_translate" to a bmp file, it appeared as all
> > white, but when I chose to call
> > "poVRTBand->AddSimpleSource"
> > instead of
> > "poVRTBand->AddComplexSource"
> > it worked,
> > Can you tell me why?
> > Driver: GTiff/GeoTIFF
> > Band 1 Block=375x1 Type=Float32, ColorInterp=Gray
> only 1 Band  is a  "SIMPLE SOURCE"
> HTH
> Norman
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
__________________________________________________
Do you Yahoo!?
Yahoo! Platinum - Watch CBS' NCAA March Madness, live on your desktop!
http://platinum.yahoo.com
