[Gdal-dev] Error while loading shared libraries: libgdal.1.1.so
Øystein Bedin oystein.bedin at gold.sdsmt.edu
Thu Mar 27 14:05:35 EST 2003
I got it to work...
As several of you suggested, the LD_LIBRARY_PATH didn't contain the path
to where I had the library. Now I got that fixed, and I'm able to run
the programs - the support for HDF4 is also working!
Thanks to you all!
 - Øystein
On Wed, 2003-03-26 at 15:42, Øystein Bedin wrote:
> I've compiled the GDAL library with HDF4 support in Linux RedHat 8.0.
> When I try to run any of the gdal apps. (e.g: gdal_info) I get this
> error message:
> "Error while loading shared libraries: libgdal.1.1.so: cannot open
> shared object file: No such file or directory."
> Seems like the make process is going as it is supposed to - no errors.
> Any suggestions about what the problem might be?
> Thanks
> - Øystein
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-dev
