[Gdal-dev] proj4
Thu May 1 15:52:41 EDT 2003
Xiaodong Zhang wrote:
> Hi,
> I just found out that the gdal I'm using is not linked to Proj4 and I
> can not find any definition in the GDAL configure file. How can I link
> them together? Thanks.
Xiaodong,
Normally GDAL isn't directly linked to PROJ.4, it loads the PROJ.4
DLL/.so at runtime.  Just build and install PROJ.4 on your system and
hopefully it should just work.
This might be a good one for the FAQ!
Best regards,
