[Gdal-dev] Re: build gdal for mingw32 on cygwin
Martin Daly Martin.Daly at cadcorp.com
Mon May 12 10:16:40 EDT 2003
Frank,
> Of course, it would be more appropriate for me to actually
> test if the compiler is VC++, but offhand I am not sure how
> to do that.
"#ifdef _MSC_VER" could be a suitable test.
The VC++ 6.0 on-line helps says "Defines the compiler version. Defined
as 1200 for Microsoft Visual C++ 6.0. Always defined."  VC++ .NET is
>=1300.
Regards,
Martin
