FW: [Gdal-dev] MODIS Level 1B earth-view (EV) products
Andrey Kiselev dron at ak4719.spb.edu
Thu May 22 14:04:29 EDT 2003
> > Your right, the datum/ellipsoid we use is WGS84.  Two references you can
> > use are the ATBD and our recent MODIS geolocation paper:
> > Nishihama, M., Wolfe, R. E., Solomon, D., Patt, F. S., Blanchette, J.,
> > Fleig, A. J., Masuoka, E. (1997), MODIS Level 1A Earth Location Algorithm
> > Theoretical Basis Document Version 3.0, SDST-092, Lab. Terrestrial Phys.,
> > NASA Goddard Space Flight Center, Greenbelt, MD.
> >    ==> on the web at
> > http://modis.gsfc.nasa.gov/data/atbd/atbd_mod28_v3.pdf
> >           see pages 3-8 and 3-36.
> > and
> > Wolfe, R. E., M. Nishihama, A. J. Fleig, J. A. Kuyper, D. P. Roy, J. C.
> > Storey and F. S. Patt, Achieving sub-pixel geolocation accuracy
> > in support
> > of MODIS land science, Remote Sens. of Env., 83 (1-2): 31-49, Nov. 2002.
> >    ==> see page 35, end of second column.
Thank you, Norman!
I shall update driver shortly.
Andrey V. Kiselev
Home phone:  +7 812 5274898  ICQ# 26871517
