[Gdal-dev] New option to create points in polygon in ogr2ogr?
Daniel Morissette morissette at dmsolutions.ca
Sat May 24 11:45:54 EDT 2003
Frank,
For one of our projects we need to calculate label points (centroids)
for a set of shapefiles.  There is already a OGRPolygonLabelPoint()
function in mitab_geometry.cpp and we will probably use that in a custom
version of ogr2ogr.
Do you see any interest in making this a standard option in the release
version of ogr2ogr.cpp?  If yes then how would you want that option to
work?
Daniel
 DM Solutions Group              http://www.dmsolutions.ca/
