[Gdal-dev] problem converting to jpeg
Wed May 28 12:31:35 EDT 2003
Frank Warmerdam wrote:
> Tim Smith wrote:
>> I am trying to convert a NITF file into a JPEG file.
>> gdalinfo shows that the NITF has a
>> colorInterp=palette.
>> When I use gdal_translate (gdal_translate -of JPEG
>> /path/file.nitf /path/file.jpeg), the created jpeg
>> file has a colorInterp=Grey.  Is there a way to do
>> this without the loss of color?
> Tim,
> JPEG does not support paletted output files, and gdal_translate does not
> currently support converting 1 band paletted images into 3 band RGB images.
> So currently gdal_translate cannot convert the file to JPEG in a useful
> way.
> Do you really need it in JPEG?  It should convert easily to PNG,
> GeoTIFF, etc.
Tim,
In followup, I have written a Python script (pct2rgb.py) that is provides
a service to translate pseudocolored files into RGB or RGBA.  The script
is in CVS in gdal/pymod.  If you are interested in pursuing this you can
rebuild from CVS (ensuring you have the python Numeric package installed)
and then do something like:
  gdal/pymod/pct2rgb.py -of JPEG overview.ovr overview.jpg
This script is a good example of applying lookup tables in python using
the "take" operation.  The portion that applies the color table looks like
this:
# Build color table.
lookup = [ Numeric.arrayrange(256),
            Numeric.ones(256)*255 ]
ct = src_band.GetRasterColorTable()
if ct is not None:
     for i in range(min(256,ct.GetCount())):
         entry = ct.GetColorEntry(i)
         for c in range(4):
             lookup[c][i] = entry[c]
# Do the processing one scanline at a time.
for iY in range(src_ds.RasterYSize):
     src_data = src_band.ReadAsArray(0,iY,src_ds.RasterXSize,1)
     for iBand in range(out_bands):
         band_lookup = lookup[iBand]
         dst_data = Numeric.take(band_lookup,src_data)
         tif_ds.GetRasterBand(iBand+1).WriteArray(dst_data,0,iY)
Best regards,
