[Gdal-dev] color table
Thu May 29 17:47:57 EDT 2003
Xiaodong Zhang wrote:
> Hi,
> I want to use GDALRasterBand::SetColorTable(GDAL ColorTable * ctb) to
> attach a color table to the image I created. How can I define the color
> table or if I have a predefined color table (3 columns, each column for
> R, G, B respectively), how can import that color table. Thanks.
This is example code for creating a GDALColorTable object in C++.  The source
data in this case uses normalized color values (0.0 to 1.0) so it has to be
scaled to 0 to 255.  If you don't have alpha (transparency) values make sure
you set all alpha values to 255 for opaque.
         poCT = new GDALColorTable();
         for( int iColor = 0; iColor < nColors; iColor++ )
             GDALColorEntry   sEntry;
             sEntry.c1 = (short) (padfRed[iColor]   * 255);
             sEntry.c2 = (short) (padfGreen[iColor] * 255);
             sEntry.c3 = (short) (padfBlue[iColor]  * 255);
             sEntry.c4 = (short) (padfAlpha[iColor]  * 255);
             poCT->SetColorEntry( iColor, &sEntry );
Note that many drivers do not allow you to update a colortable in place.
Good luck,
