[Gdal-dev] OGR Error on State Plane transform
Garvan Keeley garvank at optech.on.ca
Fri May 30 15:27:51 EDT 2003
Thanks Frank,
once the files were placed in the right place, the error went away and the
transform was successful.
I didn't realize there is an testing suite, where is that located?
Also, in the SetStatePlane function (SetStatePlane(int nZone, int bNAD83 =
TRUE)) is the second argument indicating whether NAD27 or NAD83 are being
used as input coordinates?
If so, is SetWellKnownGeogCS() necessary in this instance?
> Garvan,
> I have reproduced your problem.  The system isn't finding the
> stateplane.csv file.  Try pointing GEOTIFF_CSV to your
> gdal/data directory, or copying stateplane.csv (and likely
> pcs.csv and gcs.csv) to your GEOTIFF_CSV directory.
> I have also improved the error message (the text of the
> message was out of date), and a bug in the fallback code that
> uses SetLocalCS() if the state plane zone can't be fully resolved.
> Finally, I have just today made substantial other changes to
> SetStatePlane(). The C++ method now takes additional
> (optional) arguments to override the linear units from what
> the legal (aka EPSG) definition of the zone is.  It is
> common, for instance, to use NAD83 State Plane zone
> definitions, but to force the units to feet.  Converting the
> meter definition to feet is a bit tricky, but this is now all
> encapsulated in the SetStatePlane() method.
> While this changes the C++ ABI, old code should still compile
> fine since the extra arguments are defaulted.  I also added
> OSRSetStatePlaneWithUnits() to the C API for the new args,
> and left the old call unchanged so there is no C ABI change
> (just an extension).
> The autotest suite now includes some state plane testing.
> The Erdas Imagine driver now properly supports state plane
> files where the units are not the same as the expected zone units.
> A big day for state plane!
> Best regards,
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial
> Programmer for Rent
> Gdal-dev mailing list
> Gdal-dev at remotesensing.org
> http://remotesensing.org/mailman/listinfo/gdal-> dev
